i have started making some changes around this. Since a few releases ago its now possible to configure the "Thumbnail with Tracks" layout to show fields on the right. In the next update, the mini-player playlist can be configured to show not just the Track Details layout but also the Album and Tracks layout or the "Thumbnail with Tracks" layout.I will probably add a track finder panel
Wish I could test this out, but I'm stuck on XP for a while.
Quote from: ethereal12 on February 19, 2016, 07:54:44 AMWish I could test this out, but I'm stuck on XP for a while.Have you tried it on XP? It should work.
If you copy tags to another file via Ctrl-C & Ctrl-V on album & tracks, album or artist view, artwork doesn't change on the main panel though tag editor and track details panel shows the updated artwork correctly.
Quote from: redwing on February 19, 2016, 03:46:43 PMIf you copy tags to another file via Ctrl-C & Ctrl-V on album & tracks, album or artist view, artwork doesn't change on the main panel though tag editor and track details panel shows the updated artwork correctly.just trying now its all working fine for me with all the changed tags refreshed in the main panel for the different views, nor can i see why it wouldnt work.Is there any more info you can add to your report?
Really? I can replicate this bug using a fresh installation with the default settings file. It's not about changing views. Do you see the artwork in the main panel change when you paste tags?
When there is just slightly more in a list than what can be fully displayed (like 1 item too many), the scroll bar has just a small space above the down arrow where you should be able to click and cause a scroll down. It doesn't move. The same thing with clicking the down arrow of the scroll bar. It acts like it thinks the list is fully displayed.
