Author Topic: GUI changes for v3.0  (Read 1254236 times)
I created a playlist with the Duplicates Manager tool (thanks for the playlist naming prompt!).  When I selected one file and use it to replace another, the original file is not removed from the playlist, it just floats to the top with a (!).
I am not able to reproduce this. For me the replaced file is renamed to the new filename so I end up with two files in the playlist with the same name. Is it something you can reproduce or perhaps you were doing other things as the same time and maybe externally deleted the file?
I just noticed that sometimes when I use "Send To > Use File to Replace Another File" I get a confirmation dialog, and sometimes I don't.  I can't tell if there's any pattern to it.  Happens even within the same album.
MB checks if the artist and title are different between the two files. If they are MB prompts for confirmation.
To save confusion i will remove that check and always prompt
On v2.5, if you switch from album view to track details view, thumbnail browser immediately displays track count instead of album count. But v3 requires reopening of thumbnail browser to change the displayed count.
thats addressed for the next update
also the mini player that could look a lot better with some better info like total album size, total album time, track rating etc.
musicbee and dopamine miniplayer.
i have started making some changes around this. Since a few releases ago its now possible to configure the "Thumbnail with Tracks" layout to show fields on the right. In the next update, the mini-player playlist can be configured to show not just the Track Details layout but also the Album and Tracks layout or the "Thumbnail with Tracks" layout.
I will probably add a track finder panel
It happens very consistently, even for tracks deleted in other panels.  Here's a GIF: http://imgur.com/xBE6P6b
Last Edit: February 16, 2016, 09:55:16 PM by psychoadept
Not sure if this is something on my end, but it happens with every skin. When viewing the compactplayer with TM, the panel is compressed severely to the left side and the rest of the panel is completely transparent.
It happens very consistently, even for tracks delete in other panels.  Here's a GIF: http://imgur.com/xBE6P6b
yes i can reproduce using the "Replace Selected File" command (but not with the other one). I should be able to address it for the next update
Huh. It happens with both for me.  Hopefully that will fix it, anyway.
- fixes for the items stated as fixed above
- support for different views in the mini-player playlist panel
As I reported in another post, there's a bug with Controls main menu. If you click on shuffle, it toggles to auto-DJ mode as well.
Also, not sure if intentional but to change compactplayer settings, you must navigate to main player>edit>pref>layout2>config. This seems a long way from the compactplayer, It wouldbe nice to access settings from within the player itself as with v2.5.
You can access settings from menu button at the top left.
Replace issue seems to be fixed!
There is still this issue with the button positions in the genre category pop up:
And the icon boxes in the highlighting panel are off as well:
I just noticed you made it possible to launch external tools while background tasks are running.  Thank you!
ankor
I know I've setup Highlighting in the past and I've looked and looked but I can't find it.  It's probably right in front of me (wouldn't be the first time).  Hint somebody?...thanks.
Just a suggestion. How about displaying "narrow scrollbar", "show icon" for tabs, "show open/close button" on status bar options at the left side of panel layout editor? I feel they got buried deep and many wouldn't even know their existence.
+1
