Author Topic: GUI changes for v3.0  (Read 1414218 times)
Sofocl
If one file is played twice (or more) consecutive time "wave" in the "Now playing bar" > "Theater Mode" is not updated;
Sorry for my bad English.
However that's the space where the horizontal A-Z bar appears. Also where would you relocate the panel buttons (to open/close sidebar panels)? It takes up a tiny amount of vertical space but it's a clean look (imo) compared to jamming those items elsewhere.
Yes, exactly.  My A-Z jump bar is in that space currently.
AvikB
issue with podcast listing view.
artwork does not seem to get bigger.
"highlight playing track in the main panel" with "select track" option doesn't work.
SoftwareSamurai
MB3 v3.0.5883:
I've noticed that the Analyze Volume dialog doesn't seem to update while it is operating. Once I hit "Proceed", it runs, never updates, and then closes when it's finished.
Currently lowlight-scrollbar gets highlighted only when grabbed. It should highlight whenever the cursor moves around any (invisible) place of scrollbar to help finding it to grab since it's blended into the background.
  • MB Version: 3.6.9304P
With 2.5 and 3.0 being concurrently run (and that appears to be for the foreseeable future) I can't help but think the scrollbar.lowlight is wrong in it's implementation.
I know it (the lowlight) is supposed to be a subtler coloured version of the existing scrollbars.  But if you use it with 'narrow scrollbars' option, the lowlight colours tend to be too pale and the 'default' colours tend to be the ones you need for your lowlight scrollbars.
If you then change to a more noticeable colour combination for the default colours, these are too garish for use as normal scrollbars in 2.5 or if not using narrow scrollbars.
IMHO it should have been done as a highlight, then the default colours would remain consistent across 2.5 and 3.0 and a highlight only for 3.0.
I did propose an override for this earlier
with regards to the scrollbar default/lowlight elements
if it's not too difficult could you please implement
<element id="ScrollBarBorderNarrowOnly">true</element>
so if you have
<element id="ScrollbarNoArrows">true</element> active
the border attribute will only show when narrow scrollbars are used
so you can put a strong contrasting border on the scrollbar that only shows with narrow scrollbars in 3.0
I am confused. Was that ScrollBarBorderNarrowOnly setting implemented or not?
Alumni
Came across this error earlier while using the thumb browser.
I guess it didn't like me removing the contents of a category while it was still open.
MusicBee v3.0.5883.37616 (Win10.0), 11 Feb 2016 15:18:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
   at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
   at MusicBee.MusicBeeMain.#=qkhbaEWAWFyyyjar$78lrUpgiSq3H7$KYZ1IsHPywSqA=.#=qYuOtCKCfp$IjZqMAppwr3aRUjNZ9C_6YTjfAtCfyZY4=.#=q0QuPbqmoE7cLcfmmsOT3jgkqLdGj6M2wcmlEEZEyHJ0=._Lambda$__0(Graphics #=qW1PovF$bjyzpuVO5MS32Aw==)
   at #=qKL8uQ2FznFN6qRPl1lE5tg==.#=qWZzBgn4FwBhFCEPHOBOc7g==.#=q3NGwkVrYUKJfQqh25nARTQ==(#=qgxDRoRtfOk0WP1MLBZRyeXxK0mkpudAnBqgVLuoJiz4= #=qfqqaUFyQ$aH2Wus2V6khJA==)
   at #=qKL8uQ2FznFN6qRPl1lE5tg==.#=qwPa3kS0Xxd7RgszkWY490YHjeiItNfjwgdB6OEdvx6Y=.#=qSwj6G_PpW$8vqY6TLC0hkA==(#=qgxDRoRtfOk0WP1MLBZRyeXxK0mkpudAnBqgVLuoJiz4= #=q4llz5p9FdHVgP3TcLtaNmg==)
   at MusicBee.MusicBeeMain.#=qkhbaEWAWFyyyjar$78lrUpgiSq3H7$KYZ1IsHPywSqA=.#=qYuOtCKCfp$IjZqMAppwr3aRUjNZ9C_6YTjfAtCfyZY4=.#=qOcSm1A4v4lnj58$dVSr$lc99zaWMCqTHnlE6bWGPZd4=(Int32 #=q0V5z76j0dtXxUqAhFciTyw==, #=qK6f3uSMWjfSMBJtP66_dkA== #=qKh3p3y_ad5SmMbWYqSpa9A==)
   at MusicBee.MusicBeeMain.#=qkhbaEWAWFyyyjar$78lrUpgiSq3H7$KYZ1IsHPywSqA=.#=qYuOtCKCfp$IjZqMAppwr3aRUjNZ9C_6YTjfAtCfyZY4=.#=qRB45oTPZopi5w2rAMTDZMA==(Graphics #=qFC4lwHUud6uS3EcxoPUE1A==, Rectangle #=quOUmmTjkKZc6WwIGpy66TQ==)
   at MusicBee.MusicBeeMain.#=qkhbaEWAWFyyyjar$78lrUpgiSq3H7$KYZ1IsHPywSqA=.#=qYuOtCKCfp$IjZqMAppwr3aRUjNZ9C_6YTjfAtCfyZY4=.OnPaint(PaintEventArgs #=qOkRe3CmVh81Nq70g3DRZAg==)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at #=qt1YGVVGuOd1qJvhqDi$G8vUlbU2v9THjuN8X$SZXgWU=.WndProc(Message& #=qvPm8Yx7oMrm1Gi94l_Sx5w==)
what steps did you take to remove the contents eg. focus was on the main panel, Select All, then hit the delete button?
And was it the last category that was deleted?
Last Edit: February 11, 2016, 08:27:57 AM by Steven
Sofocl
MusicBee v3.0.5884.37463 (Win6.3), 11 ??? 2016 13:36:
System.ArgumentOutOfRangeException: ?????? ?? ????????? ?????????. ?????? ?????? ???? ????????????? ??????, ? ??? ?????? ?? ?????? ????????? ?????? ?????????.
??? ?????????: index
   ? System.ThrowHelper.ThrowArgumentOutOfRangeException()
   ? MusicBee.MusicBeeMain.#=qCC29ra_i_JbF1aDUxqdee8UJ8tz5RQb7befJne$JfuA=.#=qiudv_N443NdVkgZyYEAWraor1Aamrf_KsvjzqWsw1Uk=.#=qrZ5iaNtnXhRjMab8F4lYRjwL1psDopWpnHfQDIUN6t0=._Lambda$__0(Graphics #=qSzcmT9u6Zp4X5WldONnlZg==)
   ? #=qTAnFnQ7CmbgTYcjczLDzig==.#=qtINtwoyO_DwFWYbxIt4DEw==.#=qW3XTU94nHrN2OlKfJESafg==(#=qOHWQqp8N6hIdFTn5uhL$Bg0x1QjUcBN15dRjjgsj1js= #=qPTpsAVCGvBoEr9LZ7vDmlA==)
   ? #=qTAnFnQ7CmbgTYcjczLDzig==.#=q2VlEvLXsIfFVEr_eQgQJiAT2Cz6IW2Odw5yLFzdcdO0=.#=qiL_phE3UtLd6LcWYbfukRg==(#=qOHWQqp8N6hIdFTn5uhL$Bg0x1QjUcBN15dRjjgsj1js= #=qE1N_IhvR1FFBbc3ZJu6kTw==)
   ? MusicBee.MusicBeeMain.#=qCC29ra_i_JbF1aDUxqdee8UJ8tz5RQb7befJne$JfuA=.#=qiudv_N443NdVkgZyYEAWraor1Aamrf_KsvjzqWsw1Uk=.#=qX7vLEFeQsMbOrXNAXRrUt7iWGfDianBj7EwuO$J8dV8=(Int32 #=qflYi2VeRtkmYZ4I1Wu$oEg==, #=q9uHU6jQczS$Oqu0oq3wwrg== #=q0EoNimZQXqaMTxa3hTLFiA==)
   ? MusicBee.MusicBeeMain.#=qCC29ra_i_JbF1aDUxqdee8UJ8tz5RQb7befJne$JfuA=.#=qiudv_N443NdVkgZyYEAWraor1Aamrf_KsvjzqWsw1Uk=.#=qNbr79ruR7drzW4IkRmDgwQ==(Graphics #=qN58eCnA7fAsMQIp_18pzOQ==, Rectangle #=qeFz05kMWSgcG264mGFaZpQ==)
   ? MusicBee.MusicBeeMain.#=qCC29ra_i_JbF1aDUxqdee8UJ8tz5RQb7befJne$JfuA=.#=qiudv_N443NdVkgZyYEAWraor1Aamrf_KsvjzqWsw1Uk=.OnPaint(PaintEventArgs #=qvwk84SMbQf5sXdu3w1S6QQ==)
   ? System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   ? System.Windows.Forms.Control.WmPaint(Message& m)
   ? System.Windows.Forms.Control.WndProc(Message& m)
   ? #=qzdoxFSjZRv97QNTj8f3bIaeYOd0lc0wd4xHdIbr7bzY=.WndProc(Message& #=qC7Cb2wkR36nef09$3mwxLQ==)
   ? System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   ? System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   ? System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Last Edit: February 11, 2016, 08:50:52 AM by Sofocl
Alumni
I was in the process of editing my group genres/genre categories (in preferences), and the filter I had open at the time ("Unknown") had its results moved to another filter, thus would leave it blank and remove it from the browser list. I triggered a refresh to see the changes and that's when I received this error.
No.  It was never implemented.
Yeah, I got it. I'm gonna create a separate topic on dev/skins forum. Looks like there are some issues to discuss.
Adson
Question about deleting files:
I wanted to delete some files physically and simply pressed Del because I thought MB would ask me how to delete the files (library only or pyhsically).
It seems that this works different in MB3x.
Now the files are gone from the library but are still on my hd.
How can I restore the visibility of the files in the library to delete them finally?
Is there an option to show the prompt with the deletion question when pressing Del?
I searched for that in the settings area but could not find it.
Thanks in advance for your help.
