Author Topic: GUI changes for v3.0  (Read 1401025 times)
Mephisto
Also, when drag&dropping files from the windows exporer to musicbee inbox, the artwork column is not accepted as dropping area, it need to be a text column (like artist or album). Can it be changed?
Sorry to keep raising this issue, but I still cannot drop files in the artwork column of the inbox. Thanks.
Hi!!
I would like to sort the songs by language and have made a custom column for this(Sprache = language).
Now i select the the songs without language attribute--> EDIT-->TAG (2) LANGUAGE-English-->SAVE;  and this does not work!
Thanks
I will need more detail than "this does not work"
Ansem
Steven Where I can do request about a new feature for this new mb3? I would love to see a way to have sync library between PCs, and I want to suggest you a very easy way to do it :)
Steven is not adding any new features at this point.  What he's doing (and what he's done) is redesign the user interface.  Requested new features will come later.  I suggest putting your request in the Wishlist sub-forum.
A real pity, i hoped for a way to sync library between computers. I think that it should be really easy with cloud storage like mega!
I explained an easy way to do it in the wishlist topic
Boile
Hi Steven,
i dont know what you need, i would send it to you!
If i click on save the language column, it does not update.
3.4.7586
Hi Steven,
Where is MB supposed to get the language from?  Have you created a Custom Tag for language?
Boile
so you are in the tag editor and click save, and you are saying that the custom tag that you edited is not saved.
How did you confirm the new tag value is not saved?
eg. if you open the tag inspector can you see the tag values you entered (I am assuming you have configured the custom tag to save to the music file and not to the musicbee database only)
Boile
Hi!
I made a custom Tag(custom 3)-> save to music file as tag(language), than set displayed fields and dragged to selected fields!
So i got a new column for language and here can be not saved the selected language!
3.4.7586
than set displayed fields and dragged to selected fields! So i got a new column for language and here can be not saved the selected language!
i am still not following what you are doing. Can you describe using a bullet point for each step you do so that i can repeat exactly the same actions that you are doing. Assume i already have the custom tag configured.
Boile
Ok, i choose the songs without language tag in the track list(i see it in the language column) and select these, than right click and edit.
In the edit window->TAG(2)->check the custom3(now language)-> write in "German" and save.... nothing happens
3.4.7586
ok thanks, i can now reproduce this when the tag editor is docked in the main panel after the 2nd edit
scartez
Hi. Getting this error:
MusicBee v3.0.5822.40451 (Win6.0), 11 dez 2015 14:57:
System.ArgumentException: Parâmetro inválido.
   em System.Drawing.Image.get_RawFormat()
   em System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y)
   em System.Drawing.Graphics.DrawImage(Image image, Point point)
   em #=qjkEIKb0mBDFebl5mehFj1zMHTDrwgzlan5QJtYYIOn0=.#=qHPbrRcpm7EM_W$oZrrZu_w==(#=qCYftL23N$zpz5OO11Z378cXXHwpBWtW6NpNd2SsZSz0vrIcEfoWpBL24MwRexys3 #=qGQFyme7eMSnu$F0ignzDQA==)
   em #=qjkEIKb0mBDFebl5mehFj1zMHTDrwgzlan5QJtYYIOn0=.#=qNmniVFFx9d4oaoY$ghL7Tt7nFGMXElxaDGdGzIBHQbY=._Lambda$__0(Graphics #=qbCGtJB3alum9AE_$KXRACg==)
   em #=q8oIXmWuR2xq0v0qgZuyg$A==.#=qpqYwC8DipV4XtLmP5$0SYQ==.#=qiPutm_naoRQQrbRQ2VM5Ng==(Graphics #=q1hL0hy2ef$Y20Fs9uuU4QQ==, #=qFDM2Up5FnDSUUgOJjZKCgI4YsXv5nl1mzjXPzSPNxRc= #=qN$e2TDoIvbJrlR0e_YIhuQ==, Rectangle #=qbziNqtvh5VtCm3Q9OpLmJA==, Rectangle #=qiqd14gVKrnp2gw3BMnhP8Q==)
   em #=qjkEIKb0mBDFebl5mehFj1zMHTDrwgzlan5QJtYYIOn0=.OnPaint(PaintEventArgs #=qCc8Aw957z2dn_fF7Asta_g==)
   em System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   em System.Windows.Forms.Control.WmPaint(Message& m)
   em System.Windows.Forms.Control.WndProc(Message& m)
   em #=qbJG2ESJB72qsl8RqOOkod0$TUPQjD$Gi6VrtTSfDZfk=.WndProc(Message& #=qhlADoN9ERVQNcFrepF7uJg==)
   em System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   em System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   em System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
STEPS:
EDIT > PREFERENCES > LIBRARY > PRESS CHOOSE FOLDERS BUTTON
I get a crossed lines blank square and the error message (using default MusicBee 3 skin). If I use the MusicBee Classic skin, for example, the error doesn't happen.
Cheers!
When making changes that affect tag values, for example album rating and virtual album score, it won't automatically refresh the visual values in the artwork view (maybe also other views).
i cannot reproduce this. Are you displaying "Album Rating" and set it to auto-calculate? For my test i did that and changed a track rating in the main panel and from the player, both of which updated the album rating.
How did you can the rating in your case?
