Author Topic: GUI changes for v3.0  (Read 1397752 times)
cartman005
I don't think the Copy Tags issue is fixed yet. Here is a GIF showing an example.
very strange as i did test it. Perhaps its specific to m4a files. I will test that tonight or if you have time before then please try on a mp3 file
Boile
Hi!
In the Tracks Window, if you chose a custom Column and want change several Songs at once, it does not work!
One yes, more no!
Thanks
3.4.7586
Hi!
One yes, more no!
Thanks
Can you provide a screenshot of what you mean?
h0m3r
i search 2 commands for the toolbar buttons.
View: Show Column Browser
View: Show Thumbnail Browser
is it possible to add this 2 commands?
now that per tab overrides to hide the column browser has been implemented i guess its now possible for this command to hide/show the column browser for the current tab. Although you need to understand the column browser needs to be included in the default layout for this to work
I should probably also include the thumnnail browser in the current tab overrides as well
ok i understand  ;D
- you can now override display of the thumbnail browser for the current tab (hotkeys will be done for the next update)
TOP! A Hotkey is more comfortable for me. I hide the column browser normally.
Thanks for this!!!!
Last Edit: December 10, 2015, 03:33:14 PM by h0m3r
Ansem
Steven can you please make a "changelog" about what are the new featurs of this musicbee 3? I'm not talking about the daily build bugfix, but about the major things, like new lenguages used for made it,groove compatiblity, UI,ecc.
It would be a lot helpful for people like me that can't follow the forum that much,but still like to know about it :(
Hi!
(very large screenshot)
Do you mean that those fields are empty, or that can you not fill those and write them to the selected files?
Hi!
One yes, more no!
Thanks
from your screenshot i would say the custom tag values that MB has cached are out of synch with the values in the music files. Right click/ send to/ rescan files should fix that
http://www.mediafire.com/download/yg2iu46j3binune/MusicBeeDemo.zip
- the copy tags bug should be fixed this time
- slight change to the playlist manager. Now its just a normal node on the left navigator. If the left navigator is collapsed it shows Library; AudioBooks; Inbox and the playlists. This is so you can drag files from the library into a playlist. If the left navigator is not hidden then only the playlists will show. The playlist manager can now also be configured to not show, set in the Layout preferences
Ansem
Steven Where I can do request about a new feature for this new mb3? I would love to see a way to have sync library between PCs, and I want to suggest you a very easy way to do it :)
cartman005
Yes, it is working now. Thank you.
Steven is not adding any new features at this point.  What he's doing (and what he's done) is redesign the user interface.  Requested new features will come later.  I suggest putting your request in the Wishlist sub-forum.
Last Edit: December 11, 2015, 02:05:52 AM by phred
Boile
Hi!!
I would like to sort the songs by language and have made a custom column for this(Sprache = language).
Now i select the the songs without language attribute--> EDIT-->TAG (2) LANGUAGE-English-->SAVE;  and this does not work!
Thanks
3.4.7586
