Author Topic: Touch Screen compatibility  (Read 3735 times)
atomicrhinno
I finally updated my MusicBee, but now it seems that it is no longer compatiple with my touch screen.  I always liked lazily scrolling through my music with a swish of my finger. Does anybody know of a fix for this?
J3Man
I have same issue, at least in artwork view. Other views seem to work fine.
there were a lot of changes made in v2.2 to speed up the artwork panel
could you try this version to see if it makes any difference. If not, i can try one more change:
http://musicbee.niblseed.com/V2_3/MusicBee_Exe_Patched.zip
unzip and replace the existing musicbee.exe
Last Edit: February 02, 2014, 09:14:44 AM by Steven
hurdlejade
any update on it? i'm looking forward to get a touchscreen for my pc, would love to have support on scrolling.
g3on3o
i also want this feature, it's hard to use MusicBee on my tablet without at least some touchscreen scrolling functionality on the album pane.
