Hello dear community,
I recently started using MB and it's the best player so far. However I have a question concerning custom tags, which I use a lot.
Basically I have a custom tag that I'd like to take its information from a file's tag, for example the Title. Is there a way I can do this in the Tab "Tags (2)" when I click Edit on the song? I know Virtual Tags can do this by just putting <Title> for example, but is there a way to do it with custom tags?
If this doesn't work, is there a way I can programmatically loop all my files and set custom tags somehow (Not asking for code samples, I would know how to do this)? Is there a powershell or VBS interface or a MusicBee scripting console that I can use to do a foreach-loop and set properties?
greetings,
mm
