Author Topic: Display Monitored Folders in the Library panel  (Read 1885 times)
tiger960
Can I customize MusicBee so that
the monitored folders were visible in the Library panel or in any other panel,
and that I could work with and navigate on these folders such as usual folders in Computer panel?
I may have misunderstood what you mean, but if you right-click the Computer node heading in the left-hand navigation panel, there's a sub-menu Manage Folders.
There are commands there to specify which folders are displayed in the computer node - Show All Folders, Show Filtered Folders Only, Choose Filtered Folders. You can use those to make sure your monitored folders are displayed.
tiger960
Thanks.
Yes, it is very similar to that that I wanted.
One inconvenience is that it is necessary to specify these folders twice: once in settings "Managed folders" and once in the panel "Computer".
It would be possible to make separate panel "Operated folders"
