Author Topic: Music "Tracking"  (Read 2295 times)
BassT
Hello Steven,
I have some websites with PHP Fusion running,
there is an option to display the current song in Profile.
For this, you need a "SZ Tracker" Plugin for Winamp, but there seems to be no way to track your music with MediaBee.
Will there be an option to have such a Media Tracker included or as Plugin?
In PHP Fusion, the "SZ Tracker" sends the Information to a PHP Script as far I know, the script puts the information into the database.
I can send you that plugin if you need it...
Greetings
Basti
chorpo
something which do the trick -> http://getmusicbee.com/forum/index.php?topic=419.0 -> In Preferences, Now playing tab, try to enable "Show in IM Client" and then select Winamp enabled messengers.
Did this helped you?
