Author Topic: Playing Track - Displayed Tabs  (Read 4735 times)
romney_yw
I've been very grateful for a number of posts elsewhere on the forums for advice on setting these tabs up.
After experimenting for a while to see what is possible, I've settled on strings which work for me. In general, I derived these by running a normal browser session and searching for a given artist and album. In most cases, I think you can copy the string from the browser's address bar, and edit it to replace the specific names with MusicBee tags (such as <Album Artist> and <Album>) before pasting the result into the Displayed Tabs set up dialog.
I've pasted my current settings below in case they are useful to anyone else experimenting with these tabs ......
Amazon UK
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=<ASIN>
Note that I store Amazon's ASIN value in a tag on my files, which makes it very easy to find the album/track - assuming it's still available. Amazon seems to handle the search reasonably elegantly when I've not got the ASIN stored locally, or if it cannot be found.
Discogs
http://www.discogs.com/search/?q=<Album Artist>+<Album>&type=all
Music Brainz
https://musicbrainz.org/taglookup?tag-lookup.artist=<Album Artist>&tag-lookup.release=<Album>
AllMusic
http://www.allmusic.com/search/all/<Album Artist> <Album>
I guess these strings may well need to change over time as external web-sites modify their interfaces, and I don't know whether it makes any difference if you're based in a different country to the UK (where I am).
My thanks to all who share their knowledge by posting in the forums - I've learnt a lot from their generous advice.
Good luck & successful experimenting, Romney
romney_yw
Oh dear!
I've just gone back to MusicBee after finishing my post above. My custom displayed tabs are all working, but I seem to have broken the basic track details tab, which gives a nasty error message, no matter which track is currently playing .......
I don't think this is the result of my displayed tabs settings as I'm fairly sure everything was working just a little while ago - but I don't think I've changed anything else.
I'll post an entry with the error message under Bug Reports shortly, but in the meanwhile you might just want to be careful when fiddling in this area ....... :'(
romney_yw
Fixed the problem by rebooting my PC. Issue is probably not with MusicBee, but maybe with something else that MB relies on (.NET perhaps?)
Proceed with caution folks!
