Author Topic: bounch of ideas  (Read 1821 times)
Rotem K.
UI Related:
-Unmarked stars in rating column should be displayed very faded as opposed to not at all right now.
-Sorting by column will make it darker.
-The player panel really needs a gradient.
-An option: Minimize with X button.
Music Experience Related:
-A little arrow pointing up will show up near any selected filter. when you'll click on it you will the filter reset to 'ALL'. could be helpful with big filter list.
-Show all the libraries one after the other in the in the left side menu, when opening one it will automatically collapse the others.  right now the left menu is:
* Library
  - Music Files
  - Podcast
* Playlist
* Internet
* Computer
if you want to access any other library you need to do it from the menu bar. so i propose:
* Library1 ("Mp3's library" for example)
  - Music Files
  - Podcast
* Library2 ("Lossless" for example)
* Library3
* Playlist
* Internet
* Computer
-Double clicking the album art(in the right panel) will open a window(600x600) to display it.
-Maybe An option in the tag filter to find songs with Album Art that's smaller then 600x600.
