Author Topic: Problem running under Windows XP  (Read 1659 times)
pjrebordao
I've installed the latest version of MB under Windows XP -SP2.
The installation went flawlessly, but when I try to run it I get error "0xc0000135" ...
Any ideas ?
Google is your friend.  Look up the error and you'll see that it most likely has to do with a .NET problem.  Check to make sure you have .NET 4.x installed.
