Author Topic: How to delete exceptions to "auto-sweep rules" in library settings  (Read 2156 times)
nthego
I need to delete unwanted exceptions for my naming templates in the "auto-sweep rules" for organizing my library. I'm referring to the settings found at Preferences-->Library-->Monitored folders-->Organization. I have somehow created multiple exceptions to my naming template. Does anyone know how to delete these?
Any help is appreciated :)
Thanks!
nthego
Thanks for the reply.
I tried that. I'm left with a blank template but the exceptions remain. I've tried blanking them out as well.
then you are not blanking the template out - make sure you leave no spaces
nthego
I completely blanked out the template. That change is saved and remains blank. I also tried to blank out all of the exception templates but they come back after I've applied and saved all changes.
Are the templates saved in a MusicBee program folder where I could try deleting them? I've been looking for it, but unsuccessfully thus far.
Thanks again.
