Have you increased the buffer size? Edit > Preferences > Player > increase buffer size
Yes I have, as I wrote in my reply above. You can see there other settings I use that I thought might be relevant to performance).
Another thought - is the NAS set to sleep after x minutes of inactivity? Could be that the drive is slow in starting up.
To be more accurate, the HDDs are set to sleep (not the NAS) after some period (=minutes) of inactivity, yes. But that is, certainly not the reason for the problem as it happens WHILE the music is playing, i.e. while the drive is being accessed.
Also try disabled "check for updated files" and "remove dead links" on startup in the library preferences as those involve a lot of disc activity
No doubt that might help during the scan. Since I don't make changes frequently I just turn this off altogether and perform manual scans whenever necessary. Still, correct me if I'm wrong, Steven, this doesn't address the issue of stuttering when the scan is finished (which is far less frequent).
Is there any config file I can manually edit to tweak the buffer size? I don't imagine there's some method to monitor the buffer water mark, either in real time or in a log file?
Edit: forgot to thank you for taking the time and trying to help me with this issue.
MusicBee 3.5.8516 / Windows 10 (64-bit) / Intel i5-3470 / 8GB RAM
Media on NAS (CIFS share)
Get the latest patch:
https://getmusicbee.com/patches/
