> What skin are you using?
The default. I can tell you no more, since I cannot find Skins under Preferences.
Windows theme is Windows Classic.
> I've tried a couple just now and the scrollbar is visible with all of them.
Thanks.
> You might also try the latest 2.5 version
Done. No change.
