Author Topic: Any idea why Rescan won't import my M3U playlists?  (Read 10931 times)
@gpzbc:
I would suggest you report this as bug. I just tested, and MB imports m3u playlists by drag & drop without any problem (one by one though, multiple selection doesn't work) and converts it to mbp format, but if I use rescan command it only imports m3u playlists to the playlist folder without converting nor showing them under playlist node even after restart.
gpzbc
Thank you! I didn't even have time to report the bug yet!   :D
gpzbc
Sorry for the delay in responding to this.
I just added the patch and it seemed to fix it.....  the first time I tried, but it did not work any of the following times I tried.   :( ???
I applied the patch, added some playlists to the playlists folder, MB found them and added them.  I closed MB, tried the process again and it won't find or import the m3u files - even when I press "Rescan/Add Files"
chrisjj
Did this get conclusively fixed?
It appears fixed on V3.2.6827 i.e. what's now named thus:
imports playlists when that checkbox is checkmarked.
Thanks.
