Author Topic: Auto-Sync GUI improvements  (Read 17764 times)
Also, there was a bug I found. When scrolling up in down in the settings with the mouse wheel the scroll bar on the right doesn't update.
thats fixed for the next v2.5 update
unzip and replace the existing files
http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zip
- rename actions now removes the remaining folder if empty
- MTP device synching now uses a faster API to move files within the device if the device supports that API action. Otherwise MB does the copy/ delete action as now, except the delete action will be much faster
- if you start getting a lot of errors on file naming actions please let me know as it may be the new move API is not working properly
- preview now shows 2 folder levels and the filename (was 1 folder level and filename)
- fixed a few bugs with the GUI
unzip and replace the existing files:
- the update/ rename synch use-case should synch faster for MTP and USB devices
- rename file only should synch much faster
- fixes a couple of bugs in yesterday's version
- i have added an explicit option to preserve the folder structure of the source files when copying to the device (as opposed to mapping the files to a naming template). It should work better and be more clearer than the current approach of using a hacked naming template
- i dont plan to make any more changes for now. I know there have been a few requests on this topic but i would like to see some +1's before i was to consider doing them
one thing i forgot to do was to add a library filter as the music source.
This version also fixes a space calculation bug with virtual cuesheet files
*thumbs up*  Better and better!  Thanks, Steven.
Diederik
Thanks for these improvements, they make file syncing much easier and more intuitive.
you can now send specific playlists to a device using right click on the playlist in the left navigator node/ Send To/ Device...
It also integrates with the new device synch GUI so you can see the synch status when synching a playlist this way (or drag/ dropping a single playlist to a device)
In Sync Preview panel, size column is sorted as string, instead of as number.
