Author Topic: Left Pane Artwork Context Menu  (Read 3201 times)
usraek
On the artwork in the left pane when I have it showing the highlighted (but not playing) art it seems that if there is no existing artwork I cannot pull up the context menu to paste art or search the internet.
Would it be possible to include this in the future?
Thanks!
(I removed this from my previous thread, as they are separate wishes and I feel this one is more likely than the other.)
thats an oversight - this should fix it:
http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zip
unzip and replace the existing files.
However i see the left and right artwork panels dont stay in synch when updating missing artwork from the web so i will look to address that at a future date
fixed the synchronisation bugs so the left panel artwork should now work the same as the right panel
unzip and replace the existing files:
usraek
