Hi Steven,
I am using MB for playing music locally on laptop and PC's.
Having an audio set connected to a RaspBerry Pi with RASPBMC installed, I use FB as the DLNA controller.
An other audio set is connected to an ACRyan set (PlayOn HD) which has an embedded renderer that is working okay with FB.
I would like to use MB for that purpose because I prefer MB over FB, but when trying I get the message "unable to start playback (error=BASS_OK)".
I have the latest version of MB and the UPnP plugin installed and read all the posts about it.
Please advice.
You may find the log and settings in:
https://www.dropbox.com/sh/msbmy5d9xg33dis/AABpjz8aW3kRDqE23Sbl81Nia?dl=0The log will show the succesful connection to the Pi and a couple of attempts to use the ACRyan (RealtekVOD renderer).
Last.fm is not being used.
Thanks in advance,
Ton
