Author Topic: UPnP/ DLNA device support  (Read 346454 times)
louk
For those who still struggle with the Upnp/DLNA plugin showing faulty behavior, I could solve it (my MusicBee Version: 3.5.8698, recent version https://www.getmusicbee.com/downloads/).
Prerequisites:
Upnp/DLNA plugin installation:
From top bar: MusicBee->Edit->Edit Preferences->Plugins use Add Plugins button to add Upnp/DLNA plugin
("C:\Program Files (x86)\MusicBee\mb_Upnp.dll",
downloadable from https://www.getmusicbee.com/addons/plugins/11/upnp-dlna-device-support/)
and save.
Open from the footer context menĂ¼ and select: Output to->RX-A1070  (which is my Yamaha DLNA Receiver, in your case select yours)
Faulty behavior:
When you play a track, your receiver turns on, activates the server path as source, displays the track of the selected music but you hear no sound and after some seconds the next track is displayed etc.
In the MusicBee GUI you can see the marker jumping down from track to track. You can change the volume with the slider in the GUI and this also changes the volume level on the receiver, but there is still no sound.
Analysis:
I activated the log file in the Upnp/DLNA settings and could see, that the plugin informs the recipient to fetch the mp3 file from an IP, that is very likely not the public IP of my PC. I searched and found, that it was from the virtual network adapter of my VirtualBox installation and they don't host the MP3 files. That can't work.
So I checked the plugin settings and found that the IP for the server settings was set to Automatic by default. The log file showed that the plugin searches for all network adapters with their IPs and then simply selects the first one to tell the recipient where to get the MP3 file.
Extract of "C:\Users\<YourUsername>\AppData\Roaming\MusicBee\UpnpErrorLog.dat"
0; 59 Initialise - 04.11.2023 23:02:01
418; 60 GetNetworkAddresses - 192.168.56.1,dns=True,name=VirtualBox Host-Only Network,speed=1000000000
418; 61 GetNetworkAddresses - 192.168.92.1,dns=True,name=Ethernet 2,speed=1000000000
418; 62 GetNetworkAddresses - 192.168.224.1,dns=True,name=VMware Network Adapter VMnet1,speed=100000000
418; 63 GetNetworkAddresses - 192.168.200.1,dns=True,name=VMware Network Adapter VMnet8,speed=100000000
419; 64 GetNetworkAddresses - 192.168.178.44,dns=True,name=WLAN,speed=866700000
419; 65 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
419; 66 GetNetworkAddresses - http://192.168.56.1:49383
Solution:
To fix that, don't use Automatic setting but the public IP of your PC. In my case it was 192.168.178.44. Check your adapter settings or use ipconfig command in a shell to get it. You may need to restart MusicBee to get it to work.
If you are using several PCs as music servers, you should change the field for the server name to make it easier to distinguish the source on the receiver. In my case I used "MusicBee Media Library Dell", since MusicBee was running on my Dell notebook.
Last Edit: November 05, 2023, 10:15:22 PM by louk
johnnyboy
can you give more detail on that. I have Plex and Plex Amp. They work OK with their own interface. Are you saying to use the MB interface  and the plex server?
@johnnyboy, i suggest that @louk means running mb inside VirtualBox. it's a very specific case.
louk
@boroda, no, the post refers to MB installed on a Windows 10/11 PC that also has VirtulaBox or VMware installed. The same problem can occur with any other program that adds virtual network adapters and also if you have multiple hardware network adapters where the IP where the MB automatic binds to is not reachable for the receiver.
@johnyboy, Plex Amp is a different program and my post was not referring to it. In general, you will not use MB and Plex Amp together.
chinchin
This plugin works for me but not completly. Not sure if this is normal behaviour or not:
When installed and activated I can manually (on my PC) initialize playback on the DLNA Client (a Onkyo AVR) by selecting it as the playback device. The only control that I have with my AVR is play and pause in this case.
The problem is, the other way around doesn't work: the "Server" is not found by the AVR and I can't browser the library, although this option is enabled in the plugin.
Anyone familiar with this problem?
Last Edit: December 03, 2023, 10:38:51 PM by chinchin
dzeake
Hi All!
First post here...
First of all, I am blown away by MusicBee's overall functionality.  I have been using it for several years now as my desktop local music playback app without issue.  I love the customization capabilities.  The upsampling to 24/192 is an added bonus.
That all said, I started using it as a DLNA server for my living room system.  For almost 2 years, I have had no issues.  However, starting about a month ago, I started experiencing severe stuttering and lag in song playback.  It takes about 15 seconds for the system to respond to any command (fast forward, skip, stop, etc.).  The stuttering makes playback unlistenable.
There were no new variables introduced into my system that I can remember.  I am using Moode OS on a Raspberry Pi4 as renderer.  I completely reinstalled the OS, to no avail.  I am using BubbleUPNP on Android as UX.  I have reinstalled it, played with settings in the app, and even used multiple handsets to confirm that it isn't Bubble UPNP.
I am running MusicBee on the same Surface Pro tablet that it has been on for years;  Intel(R) Core(TM) i5-4300U CPU with 8 GB RAM and Windows 10.  This is the only variable that I am not sure about.  Nor have I attempted to troubleshoot Windows as a potential source of the issues.
I updated MusicBee to the latest version, and completely reinstalled it along with the UPnP/ DLNA plugin.  It initially worked perfectly, so I thought the issue was solved.  But within a few hours, the stuttering occurred again as before.
I know the plugin is no longer supported, but do any of you have any suggestions?
I humbly request that the plugin be supported again, and even promoted as one of the main features of MusicBee;  effectively you have a free alternative to the expensive Roon software suite - which is in itself pretty remarkable!
Thank you!
Last Edit: December 07, 2023, 05:43:31 PM by dzeake
The plugin will not be supported again. Steven, the plugin's developer (and the sole developer of MB) made the source code available many years ago and no one took any interest in it. And how can you promote something that isn't supported?
dzeake
Fair enough.  But sad to hear nonetheless.
dzeake
Hi All!
First post here...
Thank you!
Problem solved;  the sound driver has to be set to "WASAPI Shared" for UPnP to work correctly.  Everything runs perfectly now - no glitching, and instant access to each song selection.
I felt like Clark Griswold troubleshooting Christmas lights in Christmas Vacation;  I had toggled between Shared and Exclusive, not realizing that was the cause of my problems. ;)
lifeonmars
I know it's not especially relevant when this plugin is no longer supported, but regardless I want to say how happy I am to have discovered this exists.
I have no query, but am putting some info here in case others have a similar issue and find their way to this. I have a Sonos Move and used to be able to play my own audio files, that I keep in OneDrive, via the Sonos app. I never wanted to use the app, but saw no other choice. This hasn't worked since the spring 2024 Sonos app update. The new process of adding your music folder as a networked device is not compatible with OneDrive. Looking for solutions, I found out about this plugin. Hey presto, I can play my music on my Move again, and direct from MusicBee, which is what I ideally wanted in the first place.
BoringName
I've released a fork of this plugin.
New thread here.
The forked version of the UPnP/DLNA continues over here.
This thread is now closed.
