Author Topic: UPnP/ DLNA device support  (Read 349809 times)
johnnyboy
 :o OK I get it that if Steven is not giving up MB then thank goodness. What puzzles me is that since this topic has been active the message has been "no more development of the DLNA plugin". And yet there has been a lot of updates for all sorts of bugs, improvements etc, so some time has been spent which I appreciate. All of the recent updates I've done but have not seen any difference in the prog, it still works OK. But I still cant play gapless playback..
... What puzzles me is that since this topic has been active the message has been "no more development of the DLNA plugin"...
Yes, it is obvious that you are still puzzled.
I am even more puzzled why you are still puzzled. It has by now been explained over and over again.
... But I still cant play gapless playback ...
Do you think that if you just persist in complaining and posting here, things will change?
renius28
So this is not an integrated solution but an alternative. I've been using TuneBlade tuneblade.com for a couple years now. It has been nearly flawless in streaming music from Musicbee to a GGMM airplay-compatible receiver unit that's connected to my stereo system.
Musicbee is set to output WASAPI to virtual endpoint (virtual audio cable @ https://vac.muzychenko.net/en/). Tuneblade captures the virtual endpoint and streams to my stereo system.
Tuneblade is also compatible with most other wifi receiver protocols such as Sonos. This shout out was not sponsored.
Thibault
  • Carpe Diem
Bonjour, j'ai 2 lecteurs réseaux qui sont reconnus dans MusicBee, Cambridge CXN V2 et Panasonic 9000. En mode serveur tout fonctionne bien mais en mode controleur cela ne fonctionne pas. Impossible de jouer une musique sur mon CXN V2 par exemple. Un réglage particulier est necessaire ? J'ai peut être mal configurer le plugin UPNP/DLNA mais je crois pas. Si vous avez une idée elle est la bienvenue. Bien cordialement.
Mike Rubin
Hi.  I just installed MB this evening and added the DLNA plug-in.  It's only with this plug-in that I can use MB at all, as I play music stored on a NAS to a Sonore microrendu streamer.  MB's value to me is as a library manager and playback controller. I have selected the JRiver MC player option.
I have a large number of DSD files.  It appears that MB transcodes these files to PCM even though my streamer and DAC can handle native DSD.
I recognize that development of the DLNA plug-in has ceased, but maybe I am missing a setting.  Is there a way to stream native DSD in MB?
ZapRiver
I’ve been trying to play my music collection through Sonos and so far I’m only able to play one song, then nothing plays. I’m assuming the problem lies in the UPNP plugin. I’m a software developer. I was thinking of continuing the development of the plugin to make it work with Sonos. I urge anyone with insight into UPNP and that plugin to reply. Any help would be appreciated.
Here is the source code:
http://www.mediafire.com/file/niexv5muv655ro5/MusicBeeUpnpSource.7z/file
johnnyboy
First to Hiccup.
So you don't feel the need for a working DLNA solution. Can I ask you then what are you playing your library to? PC speakers, mobile phone? If it isn't to any HIFI device then I can understand why you are not bothered.
Renius28
I read your post regarding Tuneblade and am now trialing it. My problem with gapless playback has been solved, but there are settings etc. that need to be done when swapping between apps. So far seems promising, thanks for the heads up.
First to Hiccup.
... then I can understand why you are not bothered ...
Those are both incorrect assumptions, I never said anything like that.
ziabo
hi there!
I have 3.3.7367 installed.
DLNA plugin installed.
When I cast from my Windows 10 computer to Chromecast Ultra, sometimes the song stops followed by loud white noise.
Does anybody have the same issue? Where should I start looking for a solution?
Thank you
ziabo
511964; 217 Play - \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac (http://192.168.1.61:49382/encode/61C5B405A040FE6E-2147483373.wav)
512087; 218 StateTimer - Stopped,old=Playing
512089; 219 SyncNewPlayState - Stopped,mb=Playing
512187; 220 Profile - Generic Device, useragent=Lavf/57.83.100
512189; 221 Profile - Generic Device, useragent=Lavf/57.83.100
512190; 222 GetEncodedFile[41] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.61; mime=audio/wav,rate=44100,channels=2
512216; 223 GetEncodedFile[41] - exit=0, playtime=24
512248; 224 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
512300; 225 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
512301; 226 GetEncodedFile[42] - range=bytes 0-43276783/43276784
512302; 227 GetEncodedFile[42] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
512526; 228 GetEncodedFile[42] - exit=0, playtime=223
512957; 229 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
513081; 230 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
513084; 231 GetEncodedFile[43] - range=bytes 2161884-43276783/43276784
513086; 232 GetEncodedFile[43] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
513348; 233 GetEncodedFile[43] - exit=0, playtime=136
513708; 234 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
513720; 235 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
513722; 236 GetEncodedFile[44] - range=bytes 3830672-43276783/43276784
513725; 237 GetEncodedFile[44] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
514180; 238 GetEncodedFile[44] - exit=0, playtime=448
527193; 239 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
527202; 240 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
527203; 241 GetEncodedFile[45] - range=bytes 6952268-43276783/43276784
527204; 242 GetEncodedFile[45] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
527336; 243 GetEncodedFile[45] - exit=0, playtime=130
533698; 244 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
533710; 245 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
533713; 246 GetEncodedFile[46] - range=bytes 8525132-43276783/43276784
533715; 247 GetEncodedFile[46] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
533838; 248 GetEncodedFile[46] - exit=0, playtime=116
540201; 249 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
540212; 250 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
540215; 251 GetEncodedFile[47] - range=bytes 9832522-43276783/43276784
540216; 252 GetEncodedFile[47] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
540297; 253 GetEncodedFile[47] - exit=0, playtime=78
546946; 254 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
546957; 255 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
546960; 256 GetEncodedFile[48] - range=bytes 11092634-43276783/43276784
546962; 257 GetEncodedFile[48] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
547044; 258 GetEncodedFile[48] - exit=0, playtime=76
553564; 259 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
553570; 260 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
553571; 261 GetEncodedFile[49] - range=bytes 11823914-43276783/43276784
553572; 262 GetEncodedFile[49] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
553660; 263 GetEncodedFile[49] - exit=0, playtime=86
560261; 264 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
560269; 265 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
560270; 266 GetEncodedFile[50] - range=bytes 13156398-43276783/43276784
560271; 267 GetEncodedFile[50] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
560325; 268 GetEncodedFile[50] - exit=0, playtime=50
561004; 269 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
561018; 270 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
561020; 271 GetEncodedFile[51] - range=bytes 14215758-43276783/43276784
561022; 272 GetEncodedFile[51] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
561097; 273 GetEncodedFile[51] - exit=0, playtime=65
567697; 274 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
567711; 275 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
567714; 276 GetEncodedFile[52] - range=bytes 14648286-43276783/43276784
567716; 277 GetEncodedFile[52] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
567846; 278 GetEncodedFile[52] - exit=0, playtime=123
574264; 279 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
574278; 280 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
574281; 281 GetEncodedFile[53] - range=bytes 15938287-43276783/43276784
574284; 282 GetEncodedFile[53] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
574441; 283 GetEncodedFile[53] - exit=0, playtime=152
580699; 284 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
580712; 285 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
580715; 286 GetEncodedFile[54] - range=bytes 17199786-43276783/43276784
580717; 287 GetEncodedFile[54] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
580821; 288 GetEncodedFile[54] - exit=0, playtime=99
587383; 289 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
587397; 290 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
587400; 291 GetEncodedFile[55] - range=bytes 18509406-43276783/43276784
587403; 292 GetEncodedFile[55] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
587566; 293 GetEncodedFile[55] - exit=0, playtime=157
593887; 294 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
593896; 295 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
593897; 296 GetEncodedFile[56] - range=bytes 19736066-43276783/43276784
593899; 297 GetEncodedFile[56] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
594024; 298 GetEncodedFile[56] - exit=0, playtime=122
600399; 299 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
600413; 300 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
600416; 301 GetEncodedFile[57] - range=bytes 21013952-43276783/43276784
600418; 302 GetEncodedFile[57] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
600506; 303 GetEncodedFile[57] - exit=0, playtime=80
606883; 304 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
606897; 305 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
606900; 306 GetEncodedFile[58] - range=bytes 22279103-43276783/43276784
606903; 307 GetEncodedFile[58] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
607078; 308 GetEncodedFile[58] - exit=0, playtime=170
607417; 309 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
607429; 310 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
607431; 311 GetEncodedFile[59] - range=bytes 23347247-43276783/43276784
607432; 312 GetEncodedFile[59] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
607502; 313 GetEncodedFile[59] - exit=0, playtime=67
613763; 314 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
613775; 315 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
613777; 316 GetEncodedFile[60] - range=bytes 23791291-43276783/43276784
613778; 317 GetEncodedFile[60] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
613883; 318 GetEncodedFile[60] - exit=0, playtime=102
620295; 319 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
620302; 320 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
620304; 321 GetEncodedFile[61] - range=bytes 25037716-43276783/43276784
620306; 322 GetEncodedFile[61] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
620356; 323 GetEncodedFile[61] - exit=0, playtime=46
626763; 324 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
626775; 325 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
626778; 326 GetEncodedFile[62] - range=bytes 26121732-43276783/43276784
626780; 327 GetEncodedFile[62] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
626824; 328 GetEncodedFile[62] - exit=0, playtime=37
627226; 329 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
627236; 330 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
627238; 331 GetEncodedFile[63] - range=bytes 27000876-43276783/43276784
627239; 332 GetEncodedFile[63] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
627278; 333 GetEncodedFile[63] - exit=0, playtime=34
633689; 334 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
633697; 335 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
633698; 336 GetEncodedFile[64] - range=bytes 27332992-43276783/43276784
633700; 337 GetEncodedFile[64] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
633832; 338 GetEncodedFile[64] - exit=0, playtime=129
640232; 339 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
640245; 340 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
640247; 341 GetEncodedFile[65] - range=bytes 28480868-43276783/43276784
640250; 342 GetEncodedFile[65] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
640297; 343 GetEncodedFile[65] - exit=0, playtime=39
640743; 344 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
640750; 345 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
640752; 346 GetEncodedFile[66] - range=bytes 29294636-43276783/43276784
640753; 347 GetEncodedFile[66] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
640818; 348 GetEncodedFile[66] - exit=0, playtime=60
647298; 349 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
647310; 350 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
647313; 351 GetEncodedFile[67] - range=bytes 29726032-43276783/43276784
647315; 352 GetEncodedFile[67] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
647447; 353 GetEncodedFile[67] - exit=0, playtime=124
653701; 354 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
653714; 355 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
653716; 356 GetEncodedFile[68] - range=bytes 31201640-43276783/43276784
653719; 357 GetEncodedFile[68] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
654037; 358 GetEncodedFile[68] - exit=0, playtime=309
666510; 359 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
666522; 360 Profile - Generic Device, useragent=Mozilla/5.0 (X11; Linux aarch64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.81 Safari/537.36 CrKey/1.42.183786
666525; 361 GetEncodedFile[69] - range=bytes 33137936-43276783/43276784
666527; 362 GetEncodedFile[69] 192.168.1.61 - GET \\WDMYCLOUDMIRROR\Public\Shared Music\WD Music Library\Music\Queen\Hot Space\11 Under Pressure.flac to 192.168.1.91; mime=audio/wav,rate=44100,channels=2
666681; 363 GetEncodedFile[69] - exit=0, playtime=147
JazzMan
... I was thinking of continuing the development of the plugin to make it work with Sonos. I urge anyone with insight into UPNP and that plugin to reply. Any help would be appreciated.
I need that plugin! If you start the development, I'm willing to help. I have experience in software development, although not VB (or at least in the last 26 years). I can offer my setup, Synology NAS + Yamaha CRX-N560D, as another test platform.
Bill Gill
I am a great fan of MB but I am now tearing my hair out trying to connect it via the upnp plug-in from my Windows 10 pc to my AUNA CONNECT 100 INTERNET RADIO which is also connected to some wireless speakers to distribute the sound throughout my home. Is there anyone out there who can guide me in the right direction as to the correct settings for obtaining a consistent connection between my PC and the radio. ( ie a noddy guide ) I can get it working at times but at others it will just drop out as soon as I change what is playing. At other times it does not work at all. I have tried virtually all settings. Any suggestions would be greatly appreciated. Thanks :'(
daibaron
The plugin is working well with my Sonos Five.
I'm also ready to fund the DLNA plugin to increase the scope of compatibility
AC2N
Hello,
I use this plugin and it's work fine but when I try read *.mpc then MB say unable to start playback.. :-\
How can stream *.mpc files with this plugin I try many configuration but always "unable to start playback"
Thanks
