Author Topic: [WISH] 'Prevent Display From Sleeping' Preference  (Read 14346 times)
arcendus
Is that patched version still available?
Bit maddening that, while using a fullscreen visualizer, Windows power options (Screen > "When plugged in, turn off after #") override, causing the screen to turn off after # amount of time.
Or has anyone else discovered a fix for this? I'd rather not have to modify Windows power settings every time I want to sit and watch the visualizer for a bit, and while I know something like Caffeine exists, that too requires manual selection, which I'd like to avoid if possible.
Each patch version contains the fixes, updates, and enhancements from all the previous patch versions. You can get the latest patch from my signature below.
