I often use the "Computer" node in the navigator panel to play tracks as it is the easiest access to my music - however, MusicBee has one major drawback IMHO when using this node. I will try to explain.
I will click on one of my folders and before I know it, this folder is inside of some other folder in the tree-view. It happens so fast, that sometimes I don't even know it happened. I can't "undo" using Windows Explorer either. I must admit that this sort of thing is enough to make me re-evaluate the use of the software. I think what is happening is there is a slight delay between the down-click and up-click events and somehow the folder that I click on is dragged after the "down-click" and dropped on the "up-click". Due to the node opening up in the tree-view - the folder is always dropped somewhere else. This has already happened 5 times.
Is there a possibility to disallow "drag-and-drop" in the Navigator Panel? I only use this to navigate, not to do file opertaions.
Thanks...
