Author Topic: larger custom font: some buttons are not visible  (Read 11825 times)
gsax
log:
29.10.2014 16:29:16 - base size={Width=1645, Height=45},scale=3,05194805194805,font=[Font: Name=Segoe UI, Size=16, Units=3, GdiCharSet=1, GdiVerticalFont=False],orig hscale=2,64155844155844
29.10.2014 16:29:16 - g size={Width=1645, Height=45},scale=3,05194805194805
29.10.2014 16:29:21 - before bounds={X=0,Y=0,Width=604,Height=634},main panel={X=6,Y=31,Width=592,Height=618},main tabs={X=121,Y=-10,Width=469,Height=588},radio right=562
29.10.2014 16:29:22 - after bounds={X=0,Y=0,Width=1602,Height=987},main panel={X=3,Y=3,Width=1590,Height=949},main tabs={X=320,Y=-29,Width=1239,Height=1302},radio right=1104
screenprint: http://imageshack.com/a/img673/7485/Co40oZ.png
better this way?
important:
1.) as i use a dsp plugin called stereo tool 7.4. which has veeery small hardcoded fonts i have to set windows system fonts high = 150%
2.) i have to use my surface pro VERTICAL so, in vertical mode radiobuttons are much more cut then in horizontal mode.
3.) again: the solution of this issue would be to make the preferences and edit windows sizeable, same as the main window.
but perhaps this is not possible?
That screenshot looks as expected. Because you are using a really large font there isnt enough vertical space available but you can scroll the panel up and down.
When you change the orientation of the screen, i would say windows is forcing the window to be resized in order to fit the available space but that chops off some of the right side. However i dont plan to spend any time enhancing the window so you can scroll across in that circumstance.
For the tag editor, i will make a change because the handling for for large fonts is flawed but it might be some time before i do that
gsax
thank you, dear steven for your feedback. i understand, that this is a special situation, which would need additional programming and testing time and shure it has no priority. since i work daily with MB (concerts, liveshows) i feel quite comfortable with it. most settings are now done and i do not have to change them as much as prior. thank you again for your fantastic work - i will do my donation right now :-) looking forward to future updates & enhancements :-) best, roland G-SAX.ch
