Author Topic: larger custom font: some buttons are not visible  (Read 11829 times)
same as before, run this debug version, open the system preferences dialog and then send me the latest entries in the error log
http://www.mediafire.com/download/gcmwtipfa4aee2b/MusicBeeDebug.zip
gsax
after unzipping, starting:
MusicBee v2.5.5412.16367 (Win6.2), 27 Okt 2014 18:11:
System.TypeInitializationException: Der Typeninitialisierer für "#=qhJQxcRhrfHtHukdWa_zhKQ==" hat eine Ausnahme verursacht
TRace:
27.10.2014 18:11:49 - 6.2.9200.0 - 2.5.5412.16367 - System.TypeInitializationException: Der Typeninitialisierer für "#=qhJQxcRhrfHtHukdWa_zhKQ==" hat eine Ausnahme verursacht. ---> System.ApplicationException: Unable to load 'C:\Users\roland\Desktop\bass.dll'
27.10.2014 18:25:45 - scale=2,169573283859,2,169573283859,bounds={X=0,Y=0,Width=604,Height=643},font=[Font: Name=Segoe UI, Size=13, Units=3, GdiCharSet=1, GdiVerticalFont=False]
27.10.2014 18:25:45 - bounds after={X=0,Y=0,Width=1296,Height=1062}
27.10.2014 18:28:11 - scale=2,32244897959184,2,32244897959184,bounds={X=0,Y=0,Width=604,Height=641},font=[Font: Name=Segoe UI, Size=14, Units=3, GdiCharSet=1, GdiVerticalFont=False]
27.10.2014 18:28:11 - bounds after={X=0,Y=0,Width=1387,Height=1062}
Last Edit: October 27, 2014, 06:29:34 PM by gsax
unzip and replace the existing files - just like the last time
then open the system preferences dialog
gsax
27.10.2014 18:41:19 - base size={Width=1430, Height=38},scale=2,6530612244898,font=[Font: Name=Segoe UI, Size=14, Units=3, GdiCharSet=1, GdiVerticalFont=False],orig hscale=2,32244897959184
27.10.2014 18:41:19 - g size={Width=1430, Height=38},scale=2,6530612244898
27.10.2014 18:41:24 - before bounds={X=0,Y=0,Width=604,Height=641},main panel={X=6,Y=31,Width=592,Height=618},main tabs={X=121,Y=-10,Width=469,Height=588},radio right=532
27.10.2014 18:41:25 - after bounds={X=0,Y=0,Width=1413,Height=987},main panel={X=3,Y=3,Width=1401,Height=949},main tabs={X=281,Y=-26,Width=1089,Height=1146},radio right=968
according to those numbers everything is as expected and i cannot tie the numbers back to the screenshot you showed where the radio stations option was cut off so i am going to leave this as unsolved
gsax
ok, thank you steven.
as i said: f.e. shift-enter (main-window, edit details): radio-buttons are cut, because font is to big.
this wouldn't be a problem if the window could be resized. but this is not possible (yet) in musicbee.
resize abillity like any microsoft-window has, would be the solution of any size-problem, as far as i can see.
can you post a full screenshot of your system preferences dialog
gsax
not shure if i understand you: "system preference dialog"...
i uploaded some screenshots which shows you how shift-enter dialog looks.
this screenshots have been taken on a desktop-pc.
on my tablet the radio-buttons are even more cut.
http://imageshack.com/a/img745/3923/0QlAY9.jpg  -  14 font
http://imageshack.com/a/img673/6548/3E2R6Q.jpg -  16 font
the dialog window you were opening in the tests you just did
gsax
ah ok: this is the trace with 16.2 font: its equivalent to this JPG http://imageshack.com/a/img673/6548/3E2R6Q.jpg -  16 font
28.10.2014 09:50:38 - base size={Width=1475, Height=38},scale=2.73654916512059,font=[Font: Name=Segoe UI Semibold, Size=16.2, Units=3, GdiCharSet=1, GdiVerticalFont=False],orig hscale=2.38923933209648
28.10.2014 09:50:38 - g size={Width=1475, Height=38},scale=2.73654916512059
28.10.2014 09:50:42 - before bounds={X=0,Y=0,Width=604,Height=655},main panel={X=6,Y=31,Width=592,Height=618},main tabs={X=121,Y=-10,Width=469,Height=588},radio right=539
28.10.2014 09:50:42 - after bounds={X=233,Y=7,Width=1447,Height=995},main panel={X=6,Y=54,Width=1435,Height=957},main tabs={X=289,Y=-26,Width=1121,Height=1146},radio right=997
Last Edit: October 28, 2014, 10:01:38 AM by gsax
it seems you have not understood what i am asking.
I want to see a screenshot of your Preferences dialog - especially the tab with the Layout(1) options that has the "radio stations" option on the right side of the panel.
Given that you seem to be changing the fonts every time you do this, i will also need to know the font settings you are using when you take the screenshot.
The screenshot needs to be the entire Preferences window, not a partial screenshot that you did in the early posts, and the screenshot should not be resized in the link you provide
gsax
ah ok! hope this time its ok!
log: 28.10.2014 13:23:05 - before bounds={X=0,Y=0,Width=604,Height=634},main panel={X=6,Y=31,Width=592,Height=618},main tabs={X=121,Y=-10,Width=469,Height=588},radio right=562
28.10.2014 13:23:05 - after bounds={X=0,Y=0,Width=1602,Height=987},main panel={X=3,Y=3,Width=1590,Height=949},main tabs={X=320,Y=-29,Width=1239,Height=1302},radio right=1104
jpg:
http://imageshack.com/a/img673/1193/LAZNZD.jpg
THE PROBLEM occurs in a dramatic way, when the tablet is used in VERTICAL position! as you can see on jpg, different radio buttons can not be reached. the window cant be resized to reach the buttons. in horizontal way its better, but not really clean.
using the tablet in a vertical way makes sense most of the time working with MB within a live-act/show-act environment.
i still cant match the debug metrics with the measurements on actual screenshot. I can only guess that windows is doing some sort of scaling itself to the window which might be a result of some windows setting on your machine (complete guess but perhaps you have some sort of XP or Win7 compatibility mode set)
The only suggestion I have is to try with skinned windows borders as it appears its only the window borders that are not correct - tick "Skin Window Borders" in the skin selection menu
edit:
i have just re-read your comment and its really not helping. Could you please stick to what i ask for and stop changing things as it just confuses the situation.
Once again could you post a screenshot of just the Preferences dialog, in the normal landscape layout, with the fonts you are using.
To get a screenshot of just the preferences screen, please use the Alt PrintScreen keys to take the screenshot
Last Edit: October 28, 2014, 08:13:15 PM by Steven
gsax
thank you steve for spending time to this subject.
sorry to have confused things. i will do as you mentioned.
as i am busy now, i will prepare the informations tomorrow morning.
thx again.
