Author Topic: Music Bee won't recognise files in library.  (Read 2552 times)
doozer
I just opened Music Bee to find I can't play any music in my library and it tells me it can't locate any of the files I have added to my library
Will a rescan fix this or is there something else I can do to to get Music Bee to acknowledge the files.
Thanks.
that will happen if files are moved outside of MB eg. if you still have files organised with iTunes.
its probably easiest to remove all files and then add them back in again
doozer
Thanks for reply.
 I didn't change anything or move them anywhere else outside of MB from the last time I used MB. That's what made it seem strange that all of a sudden I couldn't play these files.
Last Edit: September 19, 2014, 02:33:02 PM by doozer
