Author Topic: "Expanded" Album View?  (Read 2413 times)
nostos156
Seen a few screenshots with an itunes like expanded album view, such as this one:
Only thing is I have no idea how to actually turn this on anywhere?
Further question: How do you save your configuration setups? I want to store it somewhere so that if I need to reinstall musicbee or something I don't need to go figuring out how I did everything again later on, or remembering exact layouts.
  • MB Version: 3.6.8878 P
first, you need to be using the 2.4 version
then make sure this option is selected on the view configuration
the options for saving configurations can be accessed from the layout icon
hope that helps  :)
nostos156
That's perfect, thanks. Turns out I wasn't using 2.4, yeah.
