Author Topic: History node - configure?  (Read 2167 times)
Anti
I don't usually have the History node displayed, but I just noticed that it records a link to soundcloud/jamendo tracks.
A 'recently played' auto-playlist will only display local files, so the History has useful information in it.
However, I don't like that it goes back for years.
Is there a way to configure the history node so it limits the time-span to six months (or a certain number of records)?
There is also a load of tracks listed at the bottom with an 'unknown' played date.
Is there any way to clean that up, or will they be listed there for good?
Thanks.
there is no configuration currently available for this node
Anti
OK, thanks.
Can you remember offhand how far back it will keep records?
Is there a way to reset it completely?
