Author Topic: 'Smooth Grey' Skin  (Read 55463 times)
Rotem K.
Image: http://i.imagehost.org/0190/The_Grey_Skin.jpg
Updated .XML: http://www.mediafire.com/file/zzkimzuzthh/Smooth%20Grey.xml
Updated .EXE: http://www.mediafire.com/?oogmomxyddm
Changes:
  - New splashscreen.
  - New 'Missing album art' photo.
  - Tabs corners issue, fixed.
  - The collapse/open arrow indicators are now the same size.
great thanks to Steven !
[Updated 21-06-2010]
 -- Some color adjustment. the XML link is updated.
Last Edit: June 21, 2010, 11:14:58 AM by Rotem K.
Rotem K.
i just posted an update on the downloads topic to support the now playing notification changes properly
Rotem K.
Hi folks,
Updated XML: http://www.mediafire.com/?jj037s52i6jjk8f
Changes this time:
- fixed colors for the "Now Playing" tabs when the list is docked in the main panel. (new feature. will only be available on MusicBee beta v1.2.3964 and later)
- few other minor color adjustments.
Rotem K.
Hello everyone,
Updated XML: http://www.mediafire.com/?qitak80mnwbtgy4
What changed:
- Implemented new elements enabled when developing the 'Pop Pink skin'.
  so make sure you have an Exe that support those (1.2.3980 or later), the first to support those is in the 'Pop Pink skin' thread.
- Tweaked the old elements: Preferences menu, edit screen, drop down menus.
- For anyone that interested at making his shot at skins: matched the skin structure with the new one in 'Pop Pink'. I feel it's better organized and easy to work with. also each element is numbered for future reference.
Those who use this skin as their default one, I recommend hitting the Notify button to get updates when ever they are available.
I don't foresee any right now but still, I don't want anyone still using buggy old versions.
Take care,
Rotem
Last Edit: November 25, 2010, 03:02:33 PM by Rotem K.
jackuars
