Author Topic: GrooveBee Skin  (Read 29533 times)
SummXo
I love it! Just think the min/max/close buttons don't match the skin. But it's great! :D
i've changed the buttons to be more consistent with the skin
http://www.mediafire.com/file/gys0duw2rgj4cgr/GrooveBee.xml
you will also need the latest beta from the downloads topic on this forum (1.2.3915+)
Last Edit: September 20, 2010, 10:15:19 PM by Steven
Nikhil
Hey can you please change the font color of the main panel and now playing panel from gray to black (or tell me what to change in the xml skin file)??  I think black font will definitely look better.
Rotem K.
Hey Nikhil,
Find:
<element id="Content[TrackDetail].Body.Default" bg="255,255,255" fg="102,102,102" />
<element id="Content[TrackDetail].ListAlternating.Default" bg="238,238,238" fg="102,102,102" />
Replace:
<element id="Content[TrackDetail].Body.Default" bg="255,255,255" fg="0,0,0" />
<element id="Content[TrackDetail].ListAlternating.Default" bg="238,238,238" fg="0,0,0" />
Nikhil, please share the results if you think it looks better
Nikhil
Thanks a lot Rotem K. :) I think the black font makes it more readable.
@ Steven.. should i just copy paste the whole xml code here??
Nikhil
hey n is there any way to make the title bar aero transparent.. like firefox 4 title bar??
Rotem K.
Find the setting elements:
<settings>
  <element id="UseNativeButtonTheme">true</element>
  <element id="UseSystemColors">false</element>
</settings>
and add this line:
<element id="DisableWindowBorders">true</element>
For sharing, upload the xml file to http://www.mediafire.com/ and post the link.
Last Edit: February 08, 2011, 10:36:23 AM by Rotem K.
Nikhil
Thanks for the quick reply, but what i meant was that is it possible to keep the tile bar and menu bar merged and then have aero transparency (similar to firefox 4 or google chrome, where title bar and tab bar are merged into 1)
Rotem K.
Oh. not right now. Steven is always adding new abilities for skinning so maybe in the future.
Blinghound
Yeah, it would be absolutely brilliant if transparency was added, imagine the skinning possibilities!  :D
