Author Topic: Discogs Tagger  (Read 127823 times)
catalonia
I have written to the creator of tagscanner, which is the only programme that has solved the error so far, to ask him what he has done and he has replied as follows:
Currently Discogs use UTF-8 values directly instead escaping it for json. So you just need read whole answer from API as UTF8 data.
can you provide an example artist and album
edit:
just tried: Lobão – Vida Bandida
and is working without issue
Last Edit: December 17, 2024, 09:07:29 AM by Steven
never mind - i can see its just the track titles that are messed up
try this plugin version
https://mega.nz/file/B1UnSKhR#iyOXFtFRtOe6AermyfliwqXfG3QAJ8utB6GsE57oejI
catalonia
Moodymann
After installing the plugin and restarting the program I get the message:
Unable to complete the Discogs authorisation: The request was aborted: Could not create SSL/TLS secure channel.
You can try again using the Configure button in the plugin preferences
When I go to plugins the plugin is always disabled, after enabling it I can click configure but it does nothing and when I apply and save the changes then go back to the preferences again the plugin will be disabled again.
Any suggestions to fix it? I'm running MusicBee 3.0.6335
I have exactly the same problem. I am using version 3.6.9171. Should I roll back to stable version?
  • Heal The World
Did you try reinstalling the plugin in case that helps things?
Strength and Honour (2025)
Nixander
I realized that the discogs tagger works for my tracks in my Inbox (they are stored on my computer where music bee is installed) but NOT for the files in the Music library (Files are on an netwerk server). Can someone replicate that problem or does someone have an idea on hot to fix that?
Thank you very much.
