Author Topic: Discogs Tagger  (Read 128803 times)
finsaah
Thanks for the update - I was having the same issue and it seems to have fixed it
finsaah
There seems to be an issue with multiple discs releases.  It's only picking up disc one for me (also picking up disc titles as track titles)
I've tried putting disc number in search box but makes no difference
example below
colorbyme
I think there is a problem with multiple disc tagging, at least on two releases I tried, It only get the first disc, but not the second one:
https://www.discogs.com/release/3354673-Various-N%C3%A5gonting-Att-%C3%84ta-N%C3%A5gonting-Att-Dricka
EDIT: Sorry I didn't see, the one before me just wrote the same thing.
I acknowledge that is the case. I will try to address this but there are some complications and it might not be straight-forward to fix.
It might be more practical just to implement including the disc # in the discogs search so only one specific disc is returned
colorbyme
That would be okey as well. I would even like that better
Last Edit: June 26, 2022, 04:21:57 PM by swedishme
Catyngla
Hi
Thanks for this plugin.
I managed to install it, however I can't activate it as it won't let me open the Discogs authorisation page:
May I ask any help to solve this?
Many thanks.
Regards
Waffle
Also struggling with the above issue.
Last Edit: March 13, 2023, 05:43:41 PM by Waffle
kirky86
Hi
Many thanks.
Regards
I'm having the same issue
Just tried now and all ok here. Perhaps its a temporary glitch on the discogs side
catalonia
I am trying with Spanish songs and the accents are not correct, is there any solution?
I don't use this plugin, but I would think the data is coming from Discogs. All MB is doing is pulling down what's there. So the solution is to correct them manually in MB, or raise the issue with Discogs.
catalonia
The strange thing is that in the discogs website the accents do not have this error, only in the plugin. That's why I was asking.
https://www.discogs.com/es/forum/thread/1094004?page=1&message_id=11342364
Someone who is more familiar will have to answer, but I don't think MB is going to change what Discogs is sending. Perhaps something else is going on here. Since I'm not a user of the plugin, I'll drop out of the conversation.
catalonia
from what they say discogs API has made changes and all applications are having problems.
Last Edit: November 20, 2024, 07:45:53 AM by catalonia
catalonia
