Author Topic: Virtual Tags  (Read 2301 times)
P.Morphy
Hi there. I've been trying to create a virtual tag that displays (in the column browser) a list of all the artists (sorted alphabetically) where the tag "album artist" is null.
AZ =$IsNull(<Album Artist>,,$Group($Sort(<Artist>),1)) does not work, so I'm probably doing something wrong.
Does anybody know if it is possible to do so?
Thanks in advance!
ma_t14
Why do you need $Group() and $Sort()? Wouldn't something as simple as the following work for you?
$IsNull(<Album Artist>,,<Artist>)
P.Morphy
Hello and thanks for your reply. When I try as you say I get a list with all the artists which also have an artist album tag. Just the opposite of what I'm trying to do, even though I can't tell why.
Pingaware
That's because ma_t14 made a small mistake. It should be $IsNull(<Album Artist>,<Artist>,). This will return Artist for every track where Album Artist has no value (which is what you want by the sounds of it).
ma_t14
Yes, thanks for the correction Pingaware
P.Morphy
That's what I was trying to do. Thank you very much both of you
