Author Topic: Is it possible to query / update the database directly?  (Read 2846 times)
aldredd
As per the title, is it possible to connect to the database externally and query it?
(I want to mass update some fields based on a file I exported from my previous player - I'm no developer, so creating an add-in is out of my depth, but know what I'm doing with databases & SQL)
thanks!
You can accomplish this kind of mass editing with the additional tagging & reporting tools plugin, if you can turn your existing data into a text file.  Look around for redwings guide to tagging from a text file, it's here and on the wiki.
aldredd
Thanks, the file can be saved as a text file so I'll take a look at that guide, thanks - but if that updates the tag, can I then use the tag to update the database itself? It's actually playcount and optionally the last played fields I want to update.
thanks again
Edit: Found a guide for doing something similar with foobar - going to see if I can get the tag-->play_count to work that way!
Last Edit: June 16, 2014, 01:22:31 PM by aldredd
aldredd
Ok, think I've managed it!
Used the tag manager addin to add the play count to the file, then had MB save the library as an XML file before re-importing that xml file with the playcounts! Worked so well I was able to do the same with Last Played Date.
Some tracks got missed along the way, but 80%+ got updated, which is good enough for me!
Glad you've had success!
