Author Topic: Proposed (optional) changes for simplified layout  (Read 127136 times)
Regarding playing track panel hotkeys,
- When you're using the hotkey for toggling show bottom pane, there's a discrepancy with Panel Layout button menus, although it's working correctly in functionality. If you tick "Do Not Display" with Panel Layout button, then the hotkey doesn't work. Also when you hide the panel with the hotkey, still "Bottom Pane" is ticked in the menu. Shouldn't it toggle between "Bottom Pane" and "Do not display" with the hotkey?
Bump.
Once playing track panel in tab is closed down, the hotkey for opening bottom pane doesn't work until you click on panel layout button and tick bottom pane again. Very annoying.
the way it works mirrors how it used to work with the buttons ie. there was no button when the panel was not active.
However its a simple change to make it work in a more useful way with the hotkey, which i have done for the next v2.4 update
Though now it always points to "Do Not Display", the hotkey's working fine now.
i have made some minor changes (however it wasnt doing that for me)
http://musicbee.niblseed.com/V2_4/MusicBee_Exe_Patched.zip
mikebo
- when switching tabs with ctrl+tab MainPanelTopBorder isn't redrawn properly
Also when after right clicking an inactive tab MB will switch to that tab and show the context menu, but MainPanelTopBorder isn't redrawn.
So a fix would be to either make it redraw properly or not switching to that tab and just showing the menu.
mikebo
MainPanelTopBorder isn't redrawn when closing the rightmost tab from it's context menu or by ctrl+w.
In tabs in caption bar mode with all buttons in caption bar, right-click menu to open configure toolbar pane is not available. Is this an oversight or not supported?
I asked about this a while back.  It's not supported.
- when the player is not docked on the bottom ie. the status bar is the bottom most panel, then the summary text is centred
How about making the text always center-aligned regardless of sidebars' widths? Currently it's affected by the width of either sidebar.
Bump. I don't get this. You made the status bar extending across the entire window. Then why is the centered text aligned with the main panel instead of the whole app? It's annoying the text keeps moving whenever I show/hide sidebars.
Pingaware
From what I remember, people complained more when it wasn't aligned with the sidebar. I was of the same opinion as you, but clearly in the minority, and Steven went with the majority.
Not sure we're talking about the same thing. I'm referring to the centered text on the status bar when the player bar is docked at the top. It's not centered of the entire app, but of the main panel.
Pingaware
I can't get that situation to occur. What exact settings are you using?
