Thanks for the scroll bar on the Manage Filters window. I still find this window useful, as it shows the filter rules as well as the filter name - in its place, this can be very helpful when housekeeping, or looking for a filter when you cannot remember what you called it .......
The additions to the right-click context menu are superb, and are mostly how I will be working with my filters in future ......
I hesitate to push my luck
- but I would like to ask for a further addition to the context menu commands. In the discussion above, redwing mentioned the facility to group Playlists into folders, which makes working with a large collection much easier. I think it would be a significant enhancement, if a similar folder facility could be added for use with filters (i.e. create/rename/delete folders and drag/drop filters into the folders). I guess this could cause issues with the Manage Filters window - but perhaps this could still display the simple flat view and ignore the folders completely?
Apologies for the delay in responding in this topic - I've been busy writing playlists to CD following the recent changes to that functionality. Thanks again for such rapid implementation.
PS: Redwing - thanks for your comments. I've learnt a lot over several years from reading your posts on the forum. (My playlists are now grouped tidily in folders .....)
