Author Topic: How can I fix windows 8 side by side scaling  (Read 1752 times)
Chaython
http://i.imgur.com/5IZFAVh.png
As you can see there is tons of room for the now playing bar but it's not scaling correctly
The latest MusicBee patches.
that will be because of the way that skin layout has been defined. You might have better luck with other skins but i suspect most will not work ideally in a crampt width layout
Chaython
Also how would I get the now playing to scale to the corner [if you go in side by side the now playing moves to wherever the corner was but it doesn't reset]
