Just some additional observations when using this plugin host and compatibilities from my own testing:
1. Tried replacing the bass_vst.dll that mb_vst wraps with version 2.4.0.8 from the Github repository (
https://github.com/r10s/BASS_VST/tree/master/bin/win32) which is dated February 27, 2015, newer than the one supplied by MB (which is the same one available at the normal BASS un4seen address ) which is dated 9/17/2013 but has a "2.4.5" version number. The changelog posted at the BASS forum (
http://www.un4seen.com/forum/?topic=5559.msg125834#msg125834) indicates:
v2.4.0.8 contain the following enhancements:
BASS_VST_Get/SetChunk added: plain binary parameter data handling
BASS_VST_Get/SetProgramParam length parameter added: to yield better .Net interoperability
Default/last parameter value handling optimized: as some VSTs can dynamically add/remove parameters
Unfortunately, this newer bass_vst.dll did not stop me having the same errors/crashes with certain VST plugins on mb_vst as the MB supplied one did. Decided to keep it anyway, I'm a sucker for a newer build
2. Partly repeating wealstarr's obs here: Acon Effect Chainer does not load, nor does the Case Meier Crossfeed <sob!> or LoudMax.
3. Both the Unlimited (Sonic Anomaly) and the Maxwell Smart 3 limiters load and work great; which one to use is a matter of taste. Nice metering and more flexibility on the Unlimited.
4. The Bauer crossfeed VST (
http://bs2b.sourceforge.net/download.html) works when loaded alone, or with the Maxwell Smart 3 limiter, but crashes if the Unlimited is chosen.
For what it's worth. I am using the Bauer and the MS-3, but if you don't need headphones crossfeed the Unlimited is the more flexible and better-GUI limiter.
I am happy with the default MB equalizer, but found that the rather cool free TDR Nova equalizer VST also works with mb_vst, at least on its own, didn't try a combo with other VSTs loaded.
Of course what is really needed is either a re-write of mb_vst or a bulit-in VST host like with the uLilith player. Here's hoping somebody will take this on. Until then, if you've tested other stuff that works with mb_vst, post here and help us out.
