Author Topic: Disable fade in on song resume  (Read 3681 times)
Cyberscum
Hello, I just found this program and I'm in love with it since it's so easy to transfer to it from iTunes, I got everything to work and look the way I want it to (kinda) but there's one thing that's bothering me and I can't find anything about it via google or the search function here.
So you have the option to disable fadeout when you pause a song but I can't find an option to disable fadein when you unpause/resume it. Is there no such function or am I just missing it? Is there a plug-in for this perhaps?
Also, it's fine if this isn't possible but is there a way to remove the arrows that show/hide lists and windows (the ones in the bottom corners for example).
Thank you in advance!
Cyberscum
Bump. Also, is it possible to reset to the first song in a playlist after it's done playing rather than the last song that it just finished playing?
holuschi
Maybe it is the option "smooth fade when stopping" you are looking for (Preferences -> Player -> sound effects)
Cyberscum
I already have that checked, it only works for stopping and not for starting.. :/
Cyberscum
One last bump. I'm guessing there's nothing out there to help me, thanks anyway.
