Author Topic: Showing trailing zeroes and total number within Disc-Track# field.  (Read 2294 times)
haggers
Sorry for the complicated title.
I used to have Musicbee set up to show my track numbers like ##/## with the disc numbers before that - so for example, track 12 on a 14 track album on disc 2 of the album would look like 02-12/14. For the life of me I simply can't remember how I set it up like this, and I'd appreciate help in doing so again. Thank you!
P.S. also if someone can tell me how to increase the padding between albums in artwork view, I'd appreciate that too. Thanks again.
Anti
Preferences -> tags(1) -> custom tags -> 'define new tags' button (otherwise known as 'virtual tags')
Label: Disk-Track
Formula: <Disc-Track#>/<Disc Count>
Also, in layout(1) -> main panel -> 'configure fields' button -> formatting
You may need to specify 00 - 00 in the box, as it might default to 0 - 00.
I don't know about the artwork padding - sounds like a theming problem?
haggers
Thank you! And yes, possibly. I hadn't updated my themes in a while so maybe updating them changed the padding value.
