Author Topic: Storing 'send to clipboard' tags as templates  (Read 4449 times)
vzell
I'm a heavy user of the "Send to clipboard" functionality of MB.
Right now you can have just one template defined in the configuration dialog under 'send to clipboard' tags.
It would be nice if you could save different templates in that dialog and then when using the functionality with the right click menu
choosing the one you need from a menu entry.
Right now I have to replace the  'send to clipboard' tags template for every new use case.
Also please support a way to enter a tab key as a delimiter between tags so that it can be easily made into tabular data.
+1
this was one of the things i was going to do but given boroda's plugin has implemented something is it still useful to have it in MB?
Yes, but only if you allow to insert raw text between tags in template.
vzell
