Author Topic: Expandable View in the Artwork layout  (Read 123425 times)
Sigma
I have a 2 CD album with 40 tracks on it. Here's how it displays in the expandable view: -
http://i.imgur.com/omvNQw9.jpg
The first 2 columns have 11 tracks in them, but the third only has 10, then the fourth has the remaining 8.
How come it displays like this rather than the first three columns having 11 tracks each, with the final column having the remaining 7?
Could the titles be extended a little farther than this?  I would think at least half the remaining space could be used without looking crowded.
Should already show titles longer than that even with ratings and love enabled.
Try disabling any other fields except title with Configure Layout pane.
Ah, you're right. I thought the other fields would be displayed below the track, the same way compilations and feat. artists are handled.
thats not a bad idea - i will have a look at that
Cool!  :)
Sigma
@scampbll - How come it says "Disc 1" and "Disc 2" in your screenshot? Mine just has a blank line between discs. Is there a setting somewhere for that?
In the Configure Layout settings, set a field (such as Disc #) for the subheader.
thats fixed for the next v2.4 update
Also i have changed the handling for any extra display fields that you might configure so they now display under the track title in a smaller font (in the same way that the artist field displays for compilations)
Sigma
Thanks gents! I use 01, 02, 03 etc. for disc numbers in tags, so it doesn't look as good. Would it be possible to add "Disc 1", "Disc 2" etc. as separator options that aren't reliant on tag info? I don't really want to have to edit all of the tags of my multi-disc albums, but it looks good when those separators are used in the expandable view, as in scampbll's screenshot in post #140.
Pingaware
I'm certain you could do it with a Virtual Tag without much effort. Haven't got the time to work out the formula for you now though.
This is awesome, Steven!  Check it out (showing Performer credits):
Sigma
There's only one thing left that bugs me about this now.
When you click on an album and the expanded view opens, the white "highlighted" box appears around the album art just for a fraction of a second. If you close the expanded view, the white box comes back and stays on screen.
When it flickers like that, it looks like it's a bug or that it's not meant to be happening. To me, it should work in either of these ways: -
1. When you click on an album, the white box appears around the album art and stays there while that album is highlighted, regardless of whether the expanded view is open or closed.
2. When you click on an album, the expanded view opens but the white box does not flicker on and off. If you close the expanded view, the white box appears so you know which album is highlighted.
But yeah, right now it looks like it's something that shouldn't be happening and on my PC, the box flickers on and off so quickly that it's basically pointless.
