It is an old topic but i'm really surprised crossfade radio stile is not solved properly still. Crossfade should be made by analyzing sound level of the last seconds of a song.
SQRsoft made the best plugin years ago, pity its not working in MusicBee
This is what they said about how it works:
The crossfade is made by analyzing sound level of the last seconds of the song to determine the best mix point, applying the level envelope curves to the beginning and end of the tracks.You can set different crossfading parameters for normal crossfade on track end and when you skip the track. This includes the mixing length so you can set the mix to 10%, 20%, etc.
This plugin includes a Gap Killer that eliminates the silence or any sound bellow the trigger level, this is applied to the start and end of the track.
This plugin also includes format converter that gets activated when you try to mix two songs with different bits per sample, sample rate or number of channels. The sample converter will automatically change the track to the format selected in the "Open wave device as...".
