Author Topic: W910i Not Showing  (Read 8259 times)
V4lve
Hi
My SE W910i phone is not showing in MusicBee (1.2.3793).  The Devices menu shows but no phone.
i recall you have a couple of other MTP phones - they are still OK and its just this phone which is new thats not working?
V4lve
Yup. The C902 is fine.  Will check the other one later when it comes home!
for anyone else having problems with MTP devices not showing up in MB, could you try this one:
http://www.mediafire.com/?ywljmomwmqd
if it works, it will show 0 as the free space or capacity on the device - at least in v4lve's case, the device doesnt support this property
it will be included in the next beta update
