Author Topic: Musicbee & ASIO4ALL  (Read 5458 times)
spithash
Hello,
I am curently using the ASIO4ALL plugin and as i can tell sound quality and some playback isuess i had improved.
But i have a problem with the sound of other programs.
For ex. I don't have sound playback on games, chrome and all windows generally when Musicbee is running and vise versa.
If i start Chrome and open a youtube video i don't have sound playback on Musicbee..  ???
I tried some settings in both ASIO4ALL and Mucibee but nothing.
I hope there is a solution to this..  ::)
Thank you in advance.
ASIO & WASAPI are exclusive. You can try DirectSound which actually uses WASAPI in shared mode.
spithash
Ok, thank you for your quick answer  :)
Some of my songs (prolly are lowest quality) are disorted when playing.
ASIO fixed it.Can i fix it in DirectSound too somehow?
you could try setting the output sample rate in the windows control panel for DirectSound to 44.1K to see if that helps (I think it defaults to 48K)
