Author Topic: New Floating Panels Bug - Maybe  (Read 7945 times)
  • MB Version: 3.6.8878 P
not sure if this is a bug or me not using the floating panels correctly.
tried adding an 'AlbumTracks' panel to my widget player and everything works great until....
  • open 'Now Playing' list first and it displays correctly
  • then open 'Album Tracks' and displays correctly
  • re-open 'Now Playing' and formatting is corrupted and remains so until TM is closed
have tried naming the lists differently but am still getting conflicts with those panels
here is the file: http://www.filedropper.com/miniplayerwidgetstyle
if anyone wants to check if I'm doing something wrong, please
It's a known issue:
http://getmusicbee.com/forum/index.php?topic=8210.msg47978#msg47978
And that's why many TM views of mine have a custom now playing list panel when Album Tracks type is used.
Last Edit: March 26, 2014, 04:59:58 AM by redwing
Thanks redwing  :)
I did find that post when I did a search but as it was from 2012, and a lot of changes have been made since then (plus I also don't do a lot of TM's), I thought maybe I had missed something.
Well, you know what they say when you ASSUME something...
but it only made an ASS out of ME this time, U knew what was going on  ;D
No, I didn't notice that. Actually I was a little confused about what each button does. With the constantly changing gallery images, lots of things were going on.
It's a known issue:
I think I've lost something in between the two quotes.
I meant, I didn't notice it until you post this thread.
Last Edit: March 26, 2014, 12:45:26 PM by redwing
