Author Topic: Auto-tag using sound signiture not working  (Read 6362 times)
ken481
Hi Guys
I am new to Music Bee - i tried using the Autotag feature to identify track and subsequently tag it using the sound signiture - but i tried multiple tracks but none of them got he tag data updated.
I always get - no tags where updated.
Not sure if this requires any settings i am missing to make it work
Ken
its working ok for me, except its not updating the album tag if its blank, so i have fixed that for the next v2.4 update.
can you post a screenshot of the auto-tag dialog so i can see how you have set the parameters?
edit:
this is the updated version with the album name fix. Although i dont think that is your issue:
http://musicbee.niblseed.com/V2_4/MusicBee_Exe_Patched.zip
Last Edit: March 19, 2014, 11:32:57 PM by Steven
ken481
Thanks for your help
Can you please tell me which is the aut-tag dialog - is it found in the preferences under Tag2? - where you have a list of services from where to get the tag info?
Ken
ken481
Hi tried the latest patch - still same issue - where can i send you screenshots
Ken
Instructions for screenshots: http://musicbee.wikia.com/wiki/Screenshots
I think Steven meant Auto-tag by track configuration dialog.
Also note that it doesn't work always accurately, nor it can recognize every song. For those reasons, I rarely use the feature.
Try with some standard popular tracks to see if it's really broken or just can't recognize your tracks. At least it's working fine for me.
the settings look ok and as redwing suggests the sound signature doesnt always work. Trying myself on my own tracks its working fine.
If you want, you can PM me a link to the file and i will try to see if there isnt some other issue going on for you.
i had no problems with the file you sent. Are you sure MusicBee can connect to the internet? eg. your security software isnt blocking access
You should get a dialog that says "analysing the diigital sound signature" that displays for 15-30 secs. If that doesnt happen its likely the internet access is being blocked
ken481
Yes i get that Dialogue but the tag is not updated - it only lasts for 1-2 seconds but
It tell me no tags were updated
Yes it can connect to internet since i did manage to update cover art
Ken
ken481
IT WORKED!!!
Ok let me explain
So if you right click on the track - you need to select Auto-tag by tract and it works
Before i was selecting EDIT  - > Auto-tag now - that does not work
Ken
