Author Topic: Possible to set a “master” view across Music and Playlists  (Read 2896 times)
Kalnoc
s there a way to set a custom view to be the default for playlists as well as the Music library? I created a custom view, with all of my columns laid out the way I want but I can't get it to apply when viewing a playlist. Any way to do this? Thanks.
You can select the view from display view setting of playlist edit pane.
Alumni
If you arrange or add/remove the columns in the Auto DJ node, this should set the default columns for playlists.
Kalnoc
That did the trick. Thank you.
