Author Topic: Can I configure MB to display a column containing Last.fm scrobbles?  (Read 2831 times)
Kalnoc
I'm a new MB user (latest portable version) and I'm curious if there is any way to have my playcounts (scrobbles) from last.fm show as a column in the MB player? I could do this in foorbar2000 with an additional component. I essentially used that to represent playcount since everything I play, desktop and mobile, gets scrobbled and I wouldn't have to miss two-way syncing. I could also use those figures to build auto-playlists. If this isn't possible, does MB support two-way sync of playcounts from and Android device ( Galaxy S4, using ProPlayer for playback)?
Any help is appreciated, this is a great app.
fossii
Hey,
of course, you can display the playcounts. Just make a right click in the column row, and select
"playcount" - I guess this is the correct name, in german it is called "Abgespielt Zähler"
see picture below....
[img=http://abload.de/thumb/unbenannt1vuxv.jpg]
Kalnoc
In addition, you can sync your Last.fm play count with your library play count (Tools > Tagging Tools > Sync Last.fm Play Count).
Excellent! This is exactly what I was hoping for. Best app ever.
Thank you.
