Author Topic: Turning off auto advance?  (Read 2542 times)
philoponeria
Hi. I tried searching for my answer but I think I'm using the wrong term.
I have a much of sounds that I want to load into a playlist, listen to one, edit the tags, and press play to go to the next one. MB goes from one track to the other even when I've checked "stop after current". I'm sure that this is simple and I'm just missing it. Can anyone help me?
If it helps I'm using the base install with no fancy plugins or anything. At least not yet.
Thanks.
Last Edit: February 27, 2014, 12:56:58 PM by philoponeria
philoponeria
SOLVED!
I kept searching and found this.
Edit > Preferences > Now Playing
Changing the play now option to "Clear list and play selected tracks only" does exactly what I need to.
Thank you for the Player. It has made my music library much nicer.
